#1280108 05/18/05 04:58 AM
I'm approaching 8 years on the stock battery and although it has served me well, I think the time is near to retire it. It's never given me problems, and even survived my dead alternator episode from a year ago, but I don't want to push my luck anymore.
Tonight I had to leave the ignition switched to "on" (without the car running) while i was doing an OBD2 scan and after about 5-10 minutes the low voltage warning on my power invertor sounded (recall that the DRL's were on during this time). And sure enough when I tried to start the car it cranked slowly.
I think I'm going to go with the Motorcraft, based on what others have recommended. And who knows, maybe I'll get 8 years out of the replacement as well.
Oh and in case you're wondering, my car's only been garage-parked for 2 out of the 6 winters that I've owned it.
'98 GL V6/MTX (Plenty of mods... in my basement) '88 ST165 (mild mods, stock 8psi)
that's awesome for a battery. Mine went this past winter....was original from 98...7 years is a good run....could have stretched a bit more but was able to spend a few bucks in advance of being stranded somewhere. Gets kinda sticky with little kids.
My 98 is still going strong...
98 GL sport (V6 MTX) The Durable Duratec? - (DMD, Metal impeller WaterPump, Synth & Stinky in the tranny)
I am Canuckian
I am Canuckian
When my stock battery for the Mystique went 3 years ago I got a used battery from the wreckers. It was from a 96 too. It is still running. I figure it is bound to die soon given its age but for the last 2 winters it would take a lot to crank over but it would get the job done none the less. It just doesn't want to die.
Green 96 mystique gs 4cyl mtx 16.9 in the 1/4 mile @102500 miles 95SE in Midnight Red MTX MSDS headers and y-pipe SVT exhaust SVT UIM Optimized se TB. Full pre 98 SVT body kit 15.741 @ 87.73mph :)
I checked yesterday and the green light on the battery is barely visible, so it definitely is time to replace it.
I've had a MotoMaster battery booster for the past year, it was on sale for 50% when I got it. I got one for my parents too. I've never had to use mine, but it's well worth the peace of mind as our cars get older.
I am Canuckian
I am Canuckian
That is how my light has looked since I got the battery.
Now there's an idea, I'll check the wreckers before going to the dealer.
Hmm.. should I try for 10 years?
I just changed my battery since my car had to be boosted several times.. If I were you I would go to Walmart and Test your battery.. I went there and got mine tested.. so they said it was toast.. I replaced it with an Energizer battery for $105 or so..
cheers
*bunny banging drum walks by*
98 Contour V6 MTX CTA Exhaust/CTA Intake/MSDS Y-pipe/Bat Handling Kit/Predator Alarm/Spec1 Clutch Kit/SVT Flywheel/G Assurances Fix your car yourself "It's not a UFO." Todras
Moderated by  Gerald_dup1, mbb41_dup1
