Posts: 55 |
Ok, luckily I own a contour to compare with so I know the wind noise the mysqiue has is not normal. My mystique has soo much wind noise at the windshield area it's driving me crazy. THe windshiled is not orginal ( it's Pelkington) but it seems to be installed well and I see no gaps around or under. The wind noise is not from a small hole or leak because its all around the windshield if you try to listen to it. Simply said it sounds like you're doing 100 when you're only doing a 50 or 60, compared to the contour. the windshield noise in the mystique is like it would be in the contour if it went ( the contour) at twice the speed or with major winds against u. Any clues? I searched a ton and could not come with any results. and no its not my wipers. I tried I also taped all aroun the windshield/plastic trim and no difference. Could it be that the glass is thinner? Thanks for any comments.
98 Contour SE Sport (ZETEC)
98 Mercury Mystique LS Sport (DURATEC)
Posts: 7,100 |
Well, the mystique IS a 6, and the contour a 4... maybe you just haven't really seen enough speed in the tour to notice any wind? LOL  Seriously, though: Have you checked your windshield wiper cowls for loose screws, or missing covers? Perhaps its NOT at the windshield (all around, as you say).. perhaps you are just hearing an ambient noise that is hard to pinpoint? (wheel well liners undone and catching wind. radiator support cover (on the bottom).. etc. Ray
'99 CSVT - Silver #222/276
Posts: 3,395 |
Turn your stereo up a bit louder  Nah, sometimes it sounds the same with me, but only when its windy out
Posts: 6,198 |
Originally posted by ContourKev: Turn your stereo up a bit louder
That's what I would suggest. I've got wind noise like crazy, people comment on it a lot. Doesn't bother me though.
Posts: 3,065 |
Run some water over the molding around the windshield and see if any slips past. If it does, there is your air leak point.
Posts: 432 |
yea you most likely have a leak. Is it original factory glass, most places use this mexican crap which chips easier, is thinner and dosent usally fit right, if thats the case take a hose and squirt the windshield down and see if theres a leak .
Posts: 937 |
It does that on my mystique as well. And the window has also been replaced. There was a problem off leaks that I finally sealed up. However the noise is there and I can't figure out how to make it stop. I hate this mystique and will soon be free of it with the Mercury Sable my grandmother is giving me. Then again it's just another ford built car and I question if they are just average or below on their share of car problems?
Posts: 55 |
Yes my windshield is replaced as I mentioned previously. I once taped the whole area around and drove off and the noise didnt change. Could it be due to the fact that the 98+ mystique hoods are curved up and that air in the engine bay ends going under the hood curve in the center and hits the windshield? honestly I don't buy my own explanation but will try to block that gap and see if anything gets better. prior to 98 mystique hoods were almost flush with the wiper cowls. I read in a review once that in 98 the hood was raised to give the car a more luxurious look. I also checked my wiper cowls and taht for gaps, loose screws but everything looked normal. !!
Posts: 319 |
my old honda had that problem. the left wiper arm was set too high and was creating a whistle. 30 seconds and a socket wrench and it'll be fixed
'98.5 Black Ford Contour SE Sport 5-speed. All the SE Sport features with all the 98features that were supposed to be decontented for 98.5
'04 Silver Toyota RAV4 L Auto. Fully loaded.
Posts: 89 |
You might check the rubber strips located in front of the the engine compartment by the radiator & the strip that seals hood/cowl junction. Much earlier posts (I think from Terry Haines) suggest that they're there to control air flow in the engine compartment.....my $.02
Is the smoke alarm in your house also known as the dinner bell?
'99 Zetec VCT Daily Driver
Mild Air Filter Mod
