Posts: 3,065 |
I have a set of Pioneer 6x9s (pretty deep...) that I want to put in the front doors. Will they fit? And is it worth it to try to modify the car if the possiblity exists that they won't fit?
Posts: 1,017 |
I bet you're gonna hear a bunch of "you should've searched" on this one  IIRC, they will fit with a little drilling for new holes (pretty extensive "modification", huh?), I think some people made mounting boards for them too. I'd wait for someone else to chime in though...
1995 SE
2.5L V6/MTX
187k
Posts: 3,065 |
I did search...didn't find much. I looked under 6x9 door, etc... So basically I just drill some holes, and put something behind them to make them fit securley (MDF I'm guessing?)? And there isn't any fitment issues?
Posts: 1,303 |
if nobody else chimes in, make sure you try it and post the results
Goonz12: <---tries on mommy's cloths
Posts: 3,064 |
I had to cut a larger hole for my 6x9s and obviously redrill. I also ran into the problem of my window glass hitting the magnet on the way down. That was solved by using the 1/8in plastic back piece that the supplied grill mounts to. Basically bumped the speaker out 1/8in from the pervious location. Worked like a charm.
Posts: 624 |
I did something similar to that in my escort, then one day i shut my door with the window down and shattered my glass to pieces, i was pissed, so be careful. I don't want that to happen to you.
I don't "mod" I just fix what breaks!
98 CSVT #2527 T-Red (Limping)
98 CSVT #2228 T-Red (Donor)
98 SE Sport ATX V6 (Running again)
If swimming is good for your figure, explain whales to me!
Posts: 3,064 |
Before I added the 1/8in the window was just pairly catching the window and would still go down. So the 1/8in did more than just let it barely squeeze by. But yes, be careful.
Posts: 23 |
It all depends on the size of the magnet, compare the new speaker that you want to put in to the stock speaker. If the new one is deeper, then you will need spacers (sold at most car audio shops) Keep in mind too big of a spacer and the speaker will hit the door panel so the magnet hitting the window is only half of what you need to worry about.
*Don't put a price on a good time*
Posts: 2,163 |
chose one of these low profile 6X9s
Boston's premier high performance 2-way car coaxial speakers SL95 6 x 9" $300.00 / pair (USA) Nominal Size 60watts RMS-200 watts peak 4 ohm 35Hz-20kHz Sensitivity [1 watt (2.83v) at 1m] 92dB Mounting Depth 2-5/8" (67.0mm) Blaupunkt Overdrive Series 6x9" 3-way Coaxial speaker ODx693 Suggested Retail Price.....$219.95 Mounting Depth flush2.24 mm
Directed SX Coaxial Speaker SX690 6" x 9" Magnet, neo 40.5 g, neo Power Handling 40 60 watts RMS/120 peak Impedance 4 ohm Freq. Resp. 50Hz - 21kHz Efficiency 89 dB 90 dB @ 1 watt/1 meter Tweeter Description 25mm treated silk dome Depth 2 1/2" Grills Yes
Posts: 3,065 |
Thanks for the suggestions, and warnings everyone. contour_phoenix_when, if I wanted buy new speakers, I would just go w/ 6x8s. I already have 6x9s I wanted to put in. So no one used any MDF or anything so they don't rattle? And people have put these in w/o breaking the glass and hitting the door that aren't low profile??
