Radio
Interior
F32 7.5A
F34 7.5A
Remote amp Front
F25 20A
Keyless Entry
F32
F34
F20
Interior Lighting
F34
Footwell lamps
F34
Power Lock control Relay
F25
Power Mirrors
F34
In the Central Junction Box (CJB)
See a common occurance? F34, F32, F25, F20, are the only fuses to be affected, but the odds of them ALL being bad? slim to none.
I am trying to locate a Battery Juntion Box (BJB) fuse, or relay that is linked to all of these.
What other symptoms, if any, do you have?
Does the car start? Run? Try to start? Any CELS? horn work? I will keep looking, and I would suggest letting us know if it starts at all.. that will narrow it down significantly. Even still, start looking at the main engine fuse box for a blown fuse (though I am actually thinking it is more like a common connecting rod, or bar of some kind (UNDER the main fuse box) that powers a set of fuses.. like 5 per rod, etc.. and THAT connection is bad, causing five or 6 MAIN fuses to be bad, thus affecting multiple interior fuses... Like I said, let me keep looking, while you reply if the car runs, etc.
Ray
