Posts: 101 |
ok, just like it says...i had my pass frt rotor turned yesterday, and installed a new caliper...it is STILL dragging on the rotor. what can i do to alleviate this as cost effectively as possible? help a fellow CEG'r...thanks.
1998 SVT
2.5" exhaust to 2.25" duals, homemade intake, 94A poly RRR, B&G Autobahn Series Springs
Posts: 21,197 |
Bad brake line? The do get old and the inner liner colapses. The fluid can not flow pushing the pistons. With a 7 year old car it is possible.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 101 |
so how do i check/fix this?
1998 SVT
Posts: 21,197 |
Replace the brake line.  About $25 for a new one. Unscrew the old one, install the new one.
-'96 SE MTX 3L
Posts: 101 |
do you have a part # from oreilly or autozone for the brake line? i can call and go pick it up after i get off work...it would take about ten minutes to change...is the brake line from where to where?
1998 SVT
Posts: 21,197 |
BRAKE HOSE - FRONT for a 1998 FORD CONTOUR
Item Part No.
BRAKEWARE 70684 $16.99 Goes from the hard line to the caliper.
-'96 SE MTX 3L
Posts: 10,015 |
Make sure you use TWO CORRECT SIZE WRENCHES to undo the bolt other wise if you twist the steel line you WILL be fuxored!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 101 |
what are the correct sizes? and where do i need to undo it? at the hard line? or at the caliper? the caliper is EASY to get loose...im not concerned there...it would be the hard line that i would need to find out where...is that behind the splash shielding?
1998 SVT
Posts: 9 |
13mm I recall. Line wrenches can come in handy, but open ended will work ok.
Greg
1998 E0 T-Red
#613
