Posts: 2,007 |
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 768 |
yep it is 15mm, but get a boxed wrench w/ a long handle from Sears or you will be stripping it. notice how grease monkeys always tighten them something insane? that's not because they are doing it on purpose: left to their own devices they'd leave it out altogether. it's just because you always get to it from a bad angle. with a nice wrench you will be surprised you ever had trouble w/ it before.
Posts: 240 |
I just wanted to add that you should try to get a 6 point wrench, rather than 12 point. 6 point will be touching more surface area on the head of the bolt, less chance of rounding it off.
But while we are on the subject, is there an actual torque specification on the drain plug? I've tried searching before...
'99 SVT Contour #535/2760, born 11/30/98. Toreador Red / Prairie Tan
Wife's car: '00 Saturn LS2. Dk. Toreador Red (no joke) / Graphite
Sunday Bruiser: '67 Camaro rs/SS350 4 spd. Ermine White / Custom Yellow
Posts: 247 |
Posts: 3,788 |
Why didn't you ask me when I saw you on Saturday? I would have showed you where the plug was.
How'd you make out with the oil change?
Posts: 768 |
Originally posted by Tavis426: 6 point will be touching more surface area on the head of the bolt, less chance of rounding it off.
that's not true, though. any boxed wrench will touch at 6 points.
craftsman used to sell curiously cut open ends which -- they said -- was applying the pressure to the side of the hex rather than the edge. anybody knows what I'm talking about?
Posts: 240 |
To your first statement, I have to disagree. With a 6-point, every square mm of bolt head surface is touching wrench. How is that not better?  To your second statement, are you talking about line wrenches, like for brake lines and whatnot?
Posts: 768 |
Posts: 240 |
I see your point, alex, and I don't disagree with that. But with a 6 point, it is harder to round bolts off, that's just my experience. In your illustration, that is the spot where a 12 point wrench would be flexing, and about to let the bolt slip by to the next set of edges. I'm not saying 6 points don't flex, I'm just saying that you have less chance of having to break out the Vice-Grips when using a 6 point. As far as the wrench, I do vaguely remember those wrenches. Certainly not a standard line wrench. No worse than an open end wrench, eh? But no better? If not, I'm sure that's exactly why they didn't sell, and why they are not available anymore. After just writing that, I realize that we are kinda hijacking this thread. I think the original post's questions were answered, though?
Posts: 2,469 |
I hope you never have to remove your ypipe cause that bolt looks welded on there in rust. You might have to have that torched off,
