No there is no such thing. Basically, it's a hodge-podge of parts, mostly Ford only. Trailing arm and toe control arm bushings can be had from Ford. I wouldn't waste my time with the toe control arm bushings though. The main/forward control arm must be purchased as a complete unit from Ford.
ES has a bushing kit for the trailing arms but I found it way too harsh, plus you must remove the knuckle to install one of the bushings. Plus it's a very messy, stinky job. Your neighbors won't appreciate the clouds of thick black smoke and the smell of burning rubber......
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
