The subject doesn't really sum up my question. Help guys!
I've posted a couple of times about my'95 GL woes.
A bit of a story first....
Local mechanic said I needed a timing belt and a new EGR valve. Looked at the belt myself, it looks GOOD. I knew I should have been suspicious. Anyway, I decided to replace the EGR valve myself. CEL was on, didn't know code at time.
EGR was a PIA. I'm no mechanic. My replacement part has a piece of hose on the bottom that I assumed needed to be replace as well. What I didn't know (Used alldatadiy instructions) was that this hose contained coolant. OK, no biggie. The clamps were a [censored]. Sears didn't have 22MM crowfoot. 22mm stubby wrench took like 30 mins to loosen nut on bottom. ugh, finally got it all apart. Putting in new EGR, Cross threaded bolts, argh, cant get hose clamps back on, argh. took a break. OK, finally got it all back together. Test drive.
Argh - No change in drive-ability. Took a bit longer than usual for CEL to come back on. Now at idle instead of rough it stalls (Manual trans).
My question...
OK - I read the post on checking engine light in OBD I systems. Did the test and came up with the following....
335
522
1
172
The actual sequence was as follows: 335, 522, 335, 522, long pause, one blink, long pause, one blink, pause, 7 blinks, pause, 2 blinks, long pause, 172 again, end. I re-ran test and got same results.
OK - So if I am reading this correctly, using
http://www.therangerstation.com/tech_library/3digitcodes.html as a reference...
(335) EGR feedback signal is/was out of range - EVR or PFE
(522) Park/Neutral Position <<<normal on manual trans>>>
1 or 172 NA???
OK - So what gives. New EGR valve, still getting CEL and 335 code. Stalls at idle.
Other symptoms, related or not, who knows....
AC only blows warm, refrigerant fully pressurized. (Vacuum prob?)
Lots of pinging on acceleration
Seems less power than it used to have (I could burn rubber from stop and cant now
Oh - And one more thing. When in shop it was for Emissions inspection. To pass it required an "exhaust leak" to be fixed. New cat OR "he has a guy to weld on a new pipe" since cat was fine. Weld job a lot cheaper. Done and car passes emissions testing. (BY THE WAY, CEL and rough idle started when I picked up from mechanic, I did take back and they said EGR valve, unrelated, just a coincidence, bla bla bla). Anyway, I just found teh following on alldatadiy "NOTE: PFE/DPFE system can sense a lack of pressure in the vehicle exhaust system." Related??? I have Really suspicions and kind of cranky.
Where do I go from here?
