Posts: 13 |
I just read from a webpage saying that adding some ATF into the gas tank will improve the gas mileage. Because the ATF will help clean the engine and lube the fuel pump. it that true ? just wondering
Posts: 21,197 |
Umm the gas tank!  NO! It is fine to add some to your oil. It will act as a detergent cleaning valve deposits etc. I wouldn't run it long before doing an oil change.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 139 |
I 2nd what todras just said. Never in the gas, but yeah exactly as he said it has some detergents in it which will clean off some buildup in the engine. When I had my FD I would run some every so often to help fight buildup. Although it's a bit different in a rotary engine as by design they burn oil (it's injected into the combustion chamber), but the effect is all the same on a piston engine.
Ben
*now* '00 CSVT T-red/tan #1684/2150
*sold* '92 Galant VR-4 #580/1000
*sold* '93 FD3S TT
Posts: 2,116 |
if you want stuff to go in your gas tank, get seafoam....then you can also throw some in your crank case as well.
95 SE MTX
svt exhaust
intake
deer killer
Posts: 13 |
Posts: 137 |
i don't think it's a good idea - it can kill oxygen sensors\catalyst.
Posts: 2,116 |
are you talking about ATF or seafoam in the tank?
95 SE MTX
svt exhaust
intake
deer killer
Posts: 980 |
Originally posted by todras: I wouldn't run it long before doing an oil change.
Around 500 miles? Or less, say 50-100?
2000 Mystique LS
Duratec 2.5L MTX
Posts: 2,857 |
Originally posted by elraido: are you talking about ATF or seafoam in the tank?
i think he meant atf...only thing seafoam will do if added to your tank is make your car run better..
new,new ride!
'99 svt
black/mnb
'95 mustang gt sold!
'98 svt #800 sold!
