Rozwell911CSVT
NECO Member
SVT Contour
1999 SVT, 3 liter hybrid:
Sometimes while im hard shifting my CSVT, ill get an intermintent electrical problem, with bucking and the electrical in the car going out....feels like the car is going to die.....but it only hapens on inclines, and whe i acellerate hard in the first 3 gears....i have a good idea its a ground wire....and maybe one of the small wires because it doesn;t happen very offten....but do you guys have any ideas which ones i should check first.
Iv had both primary positive and negative battery wires replaced as well as the alternator.....this issue did not start happening until my blower resister wnet bad..could the 2 be related?
Thanks for the advice!
Lupe
i bet its your + cable grounding on the egr.
theres two nuts that hold the mega fuse asembly to the valve cover and also suports the + cable maby they came off and now the cable is lose.
98 svt sil/blu 3.0 oval heads full P&P, msds headers,bat kit,2,1/2exhaust 30 inch glasspack and 2 spintech mufflers 14.78@94mph with my mechanical arm i can shift gears in less then a twentieth of a second for sale $7000
