Timing belt? Sorry, all Contour 2.5 V6 engines have timing chains, not belts.
If you're hearing whining, it's more likely a failing serpentine belt bearing (either the idler pulley or the tensioner pulley, both fairly common failure items). Thankfully, fairly cheap and easy to replace.
