#1271066 05/07/05 03:37 PM
ASVTT Offline OP
Question for the experts
My A/C works fine and it blows cold air but I have noticed that the compressor is kicking in and out constantly. Is that normal, does the system have a leak, or what should I check for.
Thank you for your replies.
#1271067 05/07/05 04:04 PM
E
E
The short cycling of the compressor usually means you are low on 134A. Stick a thermometer in the center vent area and look for at least 40 F.
#1271068 05/07/05 05:23 PM
Same thing is happening on mine.
I had it checked and pressure was really high. Guy thinks that there is a filter (I think) in a feeder hose that may be clogged.
1998.5 T-Red on Midnight Blue SVT Build Number 5320 of 6535
#1271069 05/09/05 02:28 PM
ASVTT Offline OP
I will check for the R134 pressure and also for that filter. Do you know where exactly is this filter located?
