Posts: 1,682 |
has anyone even dyno proven gains without the cat? if anything you are talking about 1-2hp. i would like to see some plots if anyone has them.
Posts: 7,329 |
No cat will garner a couple peak HP (1-3 max) over a high-flow unit. That's about it.
Also the SHOShop offroad pipe has a spot to add a cat later if you want/need to.
Posts: 2,631 |
Are talking about high flow difference vs no cat??? I have the dyno plots from each different mod I have done to my car in my sig. If you already saw it duuuuu sorry Originally posted by bret: has anyone even dyno proven gains without the cat? if anything you are talking about 1-2hp. i would like to see some plots if anyone has them.
Merlin
281hp 324tq Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
Posts: 1,041 |
Merlin why do you have less HP with the chip installed?
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 2,631 |
My guess on the chip is that it only really increases bottom end power by adjusting different signatures of the car. By adjust timing at the bottom end some more TQ can be tricked out of the car. My guess on HP drop is dealing with timing on the top end and restrictions. My car can rev atleast to 7200 ( Don't do it even with 100 octane) and it kinda makes you go uhh I don't like those weird sounds. I experiment with 3rd gear at the track. Well, I think that the cat being free'd up/removed alows for the biggest bottle neck of the tour to be removed, allowing for bigger gains. All dyno's I have seen with the chip&Y are great togeather. As for just chip dyno's??? It just depends how it's burned. Warren at Kurtz Kustomz burned mine and said I would feel a gain in tq. Some have hp gains but with pinging. I have TQ gains with pinging with pooor gas. Originally posted by Speed Demons: Merlin why do you have less HP with the chip installed?
Merlin
Posts: 1,812 |
Chris, Sorry it took so long. Yeah, 65w vs. 55w for the high beams and low beams, respectively. There's definately more light. Noticed more of a difference with the driving light 883/885 swap.
Also, I agree with Merlin. The cat (or cats in our cars cases) are big bottle necks in the exhaust. And really, do we need THREE??? You're going to get more power w/o the cat.
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 1,041 |
So they do offer a Y-pipe that has a removeable cat right. One that i can use on the street, and than take out for track use?
Anyone know how hard or time consuming (Minus getting under the car) to take the cat out of the removable one?
Posts: 2,631 |
Sho shop said " the high flow cat is removable" I did not ask any farther into that. Originally posted by Speed Demons: So they do offer a Y-pipe that has a removeable cat right. One that i can use on the street, and than take out for track use?
Merlin
Posts: 123 |
IIRC my SHO Shop Y pipe is in 4 (maybe 3 I forget)pieces. The front pipe, the rear cylinder pipe, the cat, and (IIRC) a stub pipe from the cat to the remining exhaust. The Cat is a two pipe in, one pipe out (it merges the flow internally).
The "Off road" system replaces the cat with another section of pipe that accomplishes the merge. It should be 'convertable' from one to the other.
In any case, the power gain was significant in low to mid-range with some (smaller) upper-end gains. Yes I have a superchip as well and agree the combo chip, Y, and cat-back make a good improvement in both power and sound. Hope this helps.
Posts: 1,152 |
We have a place around here that will do anything including, removing the cat. But, I dont want to have the "check Engine" Light to come on.. Will it if I remove the cat and install a off-road Y-pipe?? Thanks, Joe
1998.5 T-RED SVT 18" Team Loco 142's W/ Dunlop Rubber 181.2hp@6900rpm/155tq@5000rpm LOTS OF MODS OF EVERY KIND.... ...Am I a guru yet??? No... not yet.
