tpx1 Offline OP
98 Contour 4 banger. My check engine light came on and the temp gauge is is higher than it usually is (usually right in the middle) it also smells like oil is burning.
are you leaking anything on the ground? and are you sure it smells like oil and not coolant?
Mike 99' Silver CSVT 95' Silver Acura Integra www.latest-craze.com
get codes pulled at autozone for free. bring back CODES, not lame-o descriptions they try to give you.
We'll go from there!
Ray
Heat issue could be thermostat or H20 pump although WP issue unlikely with a Zetec. Code could be unrelated.
