#1266947 05/03/05 08:03 AM
I recently just received my A pillar gauge pod and gauges from SPmotorsports and was wondering what the easiest method is to remove the stock a pillar. I noticed there arent any screws visible on the regular a pillar but there are some on this replacement gauge pod, do I need to worry about breaking any mounts/brackets that i may need to screw into later? I have already searched but came up with nothing, I guess most people just figure it out on their own, I just want to get it right the first time . Thanks
#1266948 05/03/05 11:16 AM
Found It
-tropictour
2000 Contour SVT Tropic Green SHO Shop CAI Bassani 1999 Contour SE BAT Kit
#1266949 05/03/05 04:21 PM
awesome, I knew there was some sort of trick to it.
#1266950 05/03/05 04:31 PM
This is by far one of the easiest mods i've done. What gauges did you go with? Let me know of you need any help.
#1266951 05/03/05 09:50 PM
I got the phantom gauges. Oil pressure, water temp (stock one has been wacky since waterpump went out) and air fuel ratio. I have a friend that will wire all of the gauges for me I just need to install the gauge pod and break through the firewall if it hasnt been done already. The reason I was originally installing these was to give me an added piece of mind while driving and more of a precautionary measure. The way its looking though these gauges will just give me more things to stress about, I guess well have to see how it works out
