#1266261 05/02/05 11:27 PM
I am looking into doing a full 3L swap or a hybrid.
My main consern is final HP numbers and reliabilty.
My coworkers dad is an expert mechanic that mantains a 800 HP Sanoma Drag truck but i am just not sure if i should go full 3L route or do a hybrid. Also, if i do go full 3.0L and i buy new heads to bump the stock compression ratio, is that pretty much doing the same thing as using stock 2.5L heads and PnP'ing them?
1998 Black SVT (#469 on 4-24-1997) Custom Cougars CAI Custom Magnaflow exhaust opt. jet-hot-coated Y-pipe B&M short shifter Stazi Rotor & Brake kit 17x7 Enkei RO56's Mirco Splitter 15.45 @ 89.03 (Stock /w worn clutch) 172HP 164TRQ (stock)
#1266262 05/02/05 11:55 PM
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
#1266263 05/03/05 08:18 AM
Cut 3L valves into the 2.5 heads, then do a PnP, and that's kinda like having full 3L heads, except you'll have split port w/ cam driven water pump (something not avaliable with 3L heads), as opposed to oval port.
87 Mustang GT 5.0L TURBO
#1266264 05/03/05 10:56 AM
2000 Contour SVT Tropic Green SHO Shop CAI Bassani 1999 Contour SE BAT Kit
#1266265 05/03/05 03:45 PM
V
V
Originally posted by Pope:
....except you'll have split port w/ cam driven water pump (something not avaliable with 3L heads), as opposed to oval port.
I'm about 101% sure that you can have a cam driven WP w/ 3L heads.... unless you specifically meant split port 3L heads w/ cam driven WP- in which case, nevermind....
-Chuck Dienzo Black 98.5 E1 SVT #5022 of 6535 Born on March 16, 1998 "If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
#1266266 05/03/05 05:58 PM
01+ oval port heads have the cam driven water pump.
#1266267 05/04/05 07:55 AM
