Hey dude did it many times.
First thing is to remove door panel. Next remove the rubber stopper on the inside of the door shell, this will give you access to one of the outside door handle nuts, the other you can easily access from inside of the door minus the panel. Next remove the three screws that hold the latch assembly to the interior of the door. You can then easily slide the latch mechanism out to undo the rods. Someone here should have an exploded view of this. Also, it is listed step by step in the Haynes Manual. Good Luck>
