I just went to
Alldata.com and the
Ford Recall website and Ford only lists the recent recall(01S22) on their website when I enter my VIN.
WTF ?
Are the ones listed on Alldata not worthy for Ford to put on their list ?
Alldata Recall list:
Bulletins for 1998 Ford Contour L4-122 2.0L DOHC VIN 3 SFI
Safety Recalls TSB Number Issue Date TSB Title
1. 01S22 SEP 01 Recall - Blower Resistor Inspection/Replacement
2. 01S22 AUG 01 Recall - Defective Heater Blower Resistor Connector
3. 01S23 AUG 01 Recall - Potential Front Coil Spring Corrosion/Fracture
4. 01M08 AUG 01 Recall - Potential Front Coil Spring Fracture
5. 00S03 MAR 00 Recall - Pressure Control Reducing Valve Replacement
6. 99S19 OCT 99 Recall - Accelerator Cable Replacement
7. 99S23 OCT 99 Recall - Replacement of Front Crash Sensors
8. 99S14 JUN 99 Recall - Headlight Switch Connector
9. 98S26 OCT 98 Recall - Gear Position Indicator Deterioration
10. 98B21 JUL 98 Recall - Engine Block Heater
11. 98S03 MAR 98 Recall - Headlamp Aiming Device Instructions
General Recalls TSB Number Issue Date TSB Title
1. 01M04 JUN 01 Campaign - Fuel Pipe Flapper Valve Additional Coverage
2. 99B23 OCT 99 Campaign - Water Pump Replacement
3. 99M08 SEP 99 Campaign - Defective Blower Resistor/Wire Connector
4. 99M07 SEP 99 Campaign - Defective Blower Switch or Resistor
5. 98B34 FEB 99 Campaign - Windshields Not Marked With AS1 Standard
6. 98B30 OCT 98 Campaign - Cooling Fan Operates Continuously
