If it is the slave cylinder (TO bearing is integrated with the slave cylinder) then the powertrain needs to be pulled to get to it. While you're in there, a nice lightened flywheel and SPEC Stage 1 clutch would make nice add-ons! The SPEC combo kit includes everything- slave cylinder, flywheel, clutch disc, and pressure plate. Easy! I would quote between 18-24 hours of labor for everything, but I charge half of what shops do (usually- Depends on the work).
Dan G. and his Cougar
Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges!
Used to have: 3.0L SVT hybrid
