Posts: 17 |
Folks,
I have been working on reproducing a sunroof gear for about a year now and I think I can finally make the numbers work. I can make it on my plastic injection machine using glass filled delrin which should be harder than anything that I have tried before. As some of you know I attempted to make the gear by casting it and injecting the mold with resin. The best I was able to do lasted a week. Using my injection machine with delrin, would make the gear last a lifetime. This is the best way to do this part that I know of. The cost of the molds has always been the problem for this gear. Because of the straight teeth and the angled teeth, the mold base is very costly. I need to be able to get a sense of how many gears I can move at $65/each. Again, because of the costs involved, buying 20 will not get you a discount. This will be the cost per gear.
Finally, the last thing that I need will be to borrow a gear to get the proper size done correctly. I returned the gear that I used to use to make the first casts. When I made that gear, the method didn't take into account for shrinkage. So, I don't have a gear the actual size which is obviously very important.
To the person that lends me the original, I will gladly return the gear plus a new one.
All of my parts are made to last or I will refund your money. End of statement.
Thanks for your feedback. I will check back in to this post to see the response and gauge the need. This is not in any way commiting you to buying one. I just need to see the volume one more time. Once started, the turn around time will be about two months.
Jeff Caplan Odometer Gears LTD 757-593-3478
Posts: 6,700 |
I'll send ya one.
PM me your address, how long will it take to get the repro back??.. wiat, 2 months, i see. Not a big deal!! I'll help anyone out that can imnprove these crappy sunroof gears.
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
Posts: 7,100 |
Jeff.. I do not use my sunroof, and if I did, I would want a stronger gear either way. I would be happy to send you my gear.. I have NO objections to ANY amount of time you need to take, to make this work..Time is not an issue for me.
PM me, or AIM
ceg ray svt
I'll be more than happy to to help.
Ray
'99 CSVT - Silver #222/276
Learned patience the hard way
Posts: 2,454 |
Jeff,
Hey it's Rick, the original person you used for the gear. When do you need the gear again and for how long? I can do without my sunroof for a little while as this isn't my daily driver, but I'd like to have it at least for a bit of the summer.
Thanks, Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
I feel Guilty, Oh so guilty
Posts: 4,789 |
My gears are all fine but my motor is shot. Can you cast one of those out of delrin?
-Mitch Hedberg
Posts: 7,100 |
Rick.. If you want yours for summer, I don't use my sunroof at ALL, and therefore wouldn't mind lending it out to Jeff. I haven't used it for probably 3 of the years I own it, simply because I know it would end up breaking, and I was avoiding it (in case I sold the car, etc) I could lend my gear for months or 6 or 8, I could care less.
This way, you can use your sunroof when you get hot..
Ray
Posts: 2,454 |
Mine just gets used when I actually drive it, but that's usually on the track so I don't have the sunroof open then. I'll let Jeff figure out which works best for him.
Rick
Buckshot77@msn.com
Posts: 9,065 |
My sunroof gears are fine. Lifetime warranty.
Posts: 6,700 |
You and your stupid awesome aftermarket reliable sunroof.
Posts: 2,807 |
Mine isn't broken yet but $65 is cheap insurance. I am interested. I'll let the others fight over who donates their gear for a free one in return  .
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
