Posts: 2,586 |
Popping I'm at wits end here, if anyone could read over my post and provide me with some ideas that would be great. dont bother replying here as I'll be placing the other post as a favorite  thanks for anyhelp guys
97 T-Red LX ATX
pre98 CF SVT front,SVT rear/side skirts
FSVT wheels
Custom Front Ford Logo (body Colour)
35% tint all around with sun visor
WP With Metal Impeller?
Elky Grills
CTA Intake
CTA Custom Dual Exhaust
Posts: 1,399 |
First thing first: take it to a DIFFERENT shop than the one that did your repairs and get an inspection done. They might see something that the guys who were looking at it for a while might miss.
From the sounds of things (opinion here) if you had the subframe bolt tightened, and it still seems loose, that would be the first place to look. My money is on a bent subframe, or a damaged body mounting point.
And double check the strut mounting. Just a feeling I get readin your post a couple of times.......
Hope that this helps!
98 Silver Frost SVT
97 BMW 540I Sport, six speed
"Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future"
"A coveted car should never stunt your life, but should make it more rich and interesting."
Posts: 2,586 |
Originally posted by Phil Rohtla: From the sounds of things (opinion here) if you had the subframe bolt tightened, and it still seems loose, that would be the first place to look. My money is on a bent subframe, or a damaged body mounting point.
if thats the case, is there anything you can even to do fix these problems (short of replacing the subframe)?
97 T-Red LX ATX
FSVT wheels
Elky Grills
CTA Intake
Posts: 1,101 |
Could also be the strut thrust bearing that needs servicing or replacing. My car does that with my GC's if I don't keep them greased and it only happens at low speeds making parking lot type turns. The popping in my case is actually the spring binding and then freeing up.
Posts: 1,399 |
Not sure what to do if you have those issues.
Get it inspected first. Then you will know what you are dealing with.
98 Silver Frost SVT
Posts: 190 |
I had the same problem. My mechanic said it was a broken spring. It was very hard to detect but he found it. Check the very top of the springs for breaks.
1999 Ford Contour SE (Black)
S&B Powerstack Air Filter
Brullen Cat-Back Exhaust System (Loud Setup)
Sylvania SilverStar Headlight Bulbs
MSN Messenger: ddasilva99@hotmail.com
Posts: 2,807 |
This is where my wife's spring broke that I just replaced. It was on the very last coil.
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 449 |
If it's a consistent pop-pop-pop it could be the strut bearings need replacing.
98.5 SVT now gone ... new wheels = 2005 330i
