Posts: 34 |
96 Contour SE V6 MTX, 125,000 mi, throwing 0133 CKT Sensor slow and 0430 Catalyst below efficiency bank 2. Last month, it gave a 0174 and 0430. One of the hoses under the TB wasn't connected, so I cleaned the TB and pluged it in and that got rid of the 174. The 430 came back. I occasionally get the engine speed dependent twangy popping noise that makes me think there is a leak in the exhaust manifold somewhere. Is that even possible? Would that throw a 430? Can I just JB weld it? The car is running great, it got great mileage evan as I set a personal best time going to Lansing.
96 Ford Contour SE MTX, SVT exhaust, KKM intake, SP Motorsports slotted rotors, KVR pads, SP5000s
-Stereo sucks
Posts: 2,017 |
Lets start with this Quote:
Ckt sensor??? P0133 is Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 1. Possible causes:
-- Contaminated HO2S.
-- Exhaust leaks.
-- Shorted/open wires.
-- Excessive fueling.
-- MAF meter.
-- Air leaks.
P0430 Catalyst System Efficiency below Limit - Bank No 2. Possible causes:
-- Use of leaded fuel.
-- Oil contamination.
-- Cylinder misfiring.
-- Damaged HO2S.
-- Damaged ECT sensor.
-- Downstream HO2S wires improperly connected.
-- Fuel pressure too high.
-- Damaged exhaust system pipe.
-- Damaged exhaust manifold.
-- Damaged muffler/tail-pipe assembly.
-- Damaged catalytic converter.
According to my service cd a p0133 with your other codes
Fuel calculations can be affected by unmetered air leaks.
Carefully inspect the following areas for potential air leaks.
-- Hoses connecting to MAF.
-- Hoses connecting to throttle body.
-- Intake manifold gasket leaks.
-- PCV disconnected.
-- Vacuum lines disconnected.
-- Improperly seated dip stick and tube.
-- Exhaust leaks at flanges and gaskets.
Are there any air leaks?
1996 2.5LT V6 Contour ATX My Tour+help/info pics
E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
Posts: 34 |
Wow, thank you very much for your response. I feel like I have a much better idea of what to look for now. My gut instinct is telling me it is some kind of exhaust leak (there was a metalic ticking noise that shows up from time to time like a manifold leak, although I'm not sure that's what it is), but it seems these cars are more prone to (and sensitive to) vacuum/air leaks, so I will double check that. I have noticed the engine has been running much cooler since the waterpump got replaced last month. Is there a way to see if the ECT was damaged? As a matter of maintanance on a 125k car, I was going to do the fuel filter (3rd time in 125k) and drop the 50k old Bosch DPs in favor of the Autolite/Motorcrafts, and change the PCV valve. I'm glad the weather has been at least a bit warmer, much easier to work on the car without going numb in the cold. Thanks
-Stereo sucks
