9
OK there was a post a few weeks ago where someone came up with a way to use poly bushings in the front lower control arms. Well my bushing are shot and I am really starting to feel it on the free way and when cornering. So if someone has the specs on the front lower control arms that would be great. I need to know the inner diameter and length of the sleeves of the control arm and the out diameter of the pins. Now one pin is convex and one is concave. I need the dimensions of the concave one. Such as length, min diameter and max diameter. I am working on a way that we can use poly bushings using are factory hardware, with just a bit of machining. Pics with the dimensions would help.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
Sorry I dont have that info.
I think that everybody is thinking you want part #s and prices. If you ask for bushing dimensions for LCA, etc. then it would be better understand by everybody.
I am just trying to help
