i got my waterpump replaced back in november because of a leek .. then in jan... then in feb.. and now in april... is anyone else haveing a rough time with water pumps...
RIP Frank Foreman. March 15 2005. died in a tragic car crash at the age of 18.<Drive Safe> 1995 Contour gl Zetec auto. 178000km
What brand pump you using?
Hmm.. Mine lasted 97K miles, replace it with the same OEM from Ford.
9
I have one with 15k miles on it from my old motor for $10 plus shipping if anyone wants it.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
i am useing the motorcraft one direct from ford
Since I bought my car in 1998 I have went through at least eight waterpumps. I can give you a little advice, if they are going out as quick as you say, you need to change your thermostat and your cap on your coolant tank also check your coolant and see if it meets the ford requirements for the contour. Never mix colors orange/green. After checking all of the above, I could get mine to last about every two years.
cta intake essilenger udp odp 9mm ford racing wires hp accel coil custom fog lights svt kit with micahs pre98 svt bumper 17 inch speedy holotype wheels 215 45 Ventus HRII tires custom wood dash magnaflow exhaust
103k on original pump.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST Pre98 Zetec - Some Mods
We replaced the water pump on my 98 2.0 Zetec in June 2004. This is an Autozone water pump.
We are having a heck of a time getting the pump out again, as removing the engine mount does not provide the clearance needed to pull the pump free.
The chiltons manual says to turn it 180 degrees, but any way I twist and turn it there's no getting it free.
Last time we took the crankshaft pulley off to get it out.
We tried jacking up the engine a bit to provide more clearance, but that did not help. Also we were afraid of jacking it up too far.
Any suggestion on making water pump removal easier?
Thanks,
Tara
W
W
I have 162k on the original water pump in my 95. I also still have the original alternator.
Bill
Bill
Living life dangerously...
Just recently I had the waterpump, pulleys, tensioner, and timing belt changed on my '96 with 105k on it, and I'm glad I did. I just bought it in March, and didn't know it's history at all. I assumed these parts were never serviced, and I was right. Once the old pump was out, you could tell the impeller was loose and worn. The pullies would grind instead of spin freely. The belt was in surprisingly good shape, though. Anyway, I now have peace of mind that that aspect of the engine is completely taken care of.
'98 Mystique Zetec w/ auto trans 103,900 miles Kenwood KDC-MPV7017 CD/MP3 HU Kenwood KFC-6889ie 6x8" 3-way speakers '96 Mystique Zetec ATX 108,000 miles
