whos got them already,which one,how much does it weigh.the people with the fidonza says it weighs 8 pounds but spmotorsports says it weighs 11,whats up with that.and what about the ur.and is it worth it.
I have the fanizia on my car and its great. its been about 5000 miles and no problem. my fw weighed about 7 pounds when i got it. by the way some people are going to try to scare you for some reason with the alm. thing (dont know why) but i have had no problem with mine (no erratic rpm or dying like people say are problems with them) by the way the fan. flywheel imho is a better deal. same thing as the ur without the name go figure? :p
98 Svt Toudor red/ Silver(Two tone)
Midnight Blue and Black Carbon fibre Kit
SCA Cold Air Intake
Unorthodox Stage 1 Clutch
Fananzia Flywheel @ 8 lbs
Poly Engine Mount Inserts
Bosch Plat +4 Plugs
8.5mm Magnacore Wires
80/100 Watt Light conv.
Alpine 7864 SE Silver Head unit
Alpine GEQ 320 Digital Crossover linked to head unit via AI-Net
Phenix Gold M44 amp for highs and mids.
PPI PS2100 for JL12W6 flush mounted in rear spare tire hold.
I have the Fidanza flywheel and it is definately heavier than 7 or 8 pounds. I would guess closer to 11 or 12 pounds. It's still much lighter than stock. I have only had it in for about a week and I will say that my car revs faster since I find myself shifting more quickly than before. I haven't had any issues with it, but it's still early. I'll post if anything changes.
98 Black E0 #946 of 6535 Koni struts & Eibach springs 24mm Aussiebar Pro Flow 75mm MAFS calibrated to KKM filter Wilwood Brake Kit with cross-drilled rotors Clutchmaster's Stage 1 Clutch & Fidanza Flywheel Custom Dual Exhaust with an Xpipe MSDS Headers Custom Cold Air Intake with KKM filter Dyno'd at 177 hp and 156 ft-lbs
I had my stock SVTs flywheel lightend by 6lbs and its been running great sice late 98. Revs alot faster...
Allthough, I do have to be a little easier on the clutch from a stop or the rpms will drop to fast and die...
David Zambrano svt_mondeo at yahoo dot com CSVT E1 #4808 - soon to be 400hp You get what you pay for. All advice here is free. http://www.geocities.com/svt_mondeo- my homepage
