I know we have an audio section but this isnt about a Contour, so I decided to post it in C.I., I hope no one minds . Anyways, today I was helping my buddy trouble shoot a stereo problem with his 92 Honda Civic Si and something went wrong. The original problem was the left side of the car wouldnt play any audio whatsoever, so we pulled the aftermarket deck out to see if everything was connected properly. To our amazement, it wasnt, the wire for the left hand side of the car wasnt connected. So we connected it and tried the deck out to see if we fixed the problem. WEll we goto turn on the deck and NO POWER to the deck at all. We checked all teh connections and undid what we did and nothing still. We even bought another wiring harness and hooked it up to a different deck and still no power whatsoever. I checked all the fuses and nothing, none of them are blown. I checked the cigarette lighter(it runs off the same fuse) to see if it worked and yes it did. There is an odd thing tho, for some reason the clock is showing up very dim and we have no idea why and im not too sure if the clock is related to the radio in any way or not. So this is where we are at now and we dont know waht do to. The original honda harness and wiring looks mint and its not the wiring we did cause its all new now. Does anyone have any idea what it could be? Any help would be greatly appreciated!
Thanks in Advance
Dion
1995 Ford Mustang GT Magnaflow Exaust Clear Corners BBK Cold Air Intake MSD Ignition Alpine Security System 2 12' Alpine Type S Subs in Alpine Box Sony 1100W Mono Amp JVC CD/WMA/MP3 Deck Sold!!! 1996 Ford Contour GL
since you checked fuses, cig. lighter, got a new harness, etc...then my only guess would be something is up with the head unit.
Go get a cheap volt meter from Radio shack and check the Yellow , Red and see if your getting 12 volts . also check and make sure your ground is grounded .
Check me out for awsome powder coating deals www.powdercoatingworld.com People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
We have tried two different head units
Thats what we are gonna try today to see if anything is up with that
#1249376 04/19/05 05:22 AM
We got the deck to work now but we have a problem. The deck and the clock will not keep there memory. When you turn the car off, then on, the clock says 1:00 and the deck is in Demo mode. Now should we switch the 12v ignition and 12v battery wires to see if thats gonna solve the problem? Or does anyone have any other idea why its not keeping memory?
Thanks
Dion
#1249377 04/19/05 05:38 AM
yes, switch red and yellow.
Warning: Management is not responsible for lost or stolen virginity.
