#1249175 04/18/05 12:10 AM
Hello,
How can I tell whether I have keyless entry or not, or an alarm. I have a 98 Contour GL Sport 2.5L. When I bought it it didn't come with remotes but now i'm wondering if he just didn't have them?? How would I be able to tell? The car also has a blinking light near the clock my friends doesn't what does this mean??
Thanks,
Mike
N
N
First do a lillte research and you will find where to check if you have the connector to enter into the programming mode for the keyless entry. If i remember well it's behind the glovebox compartment.
There is non Contique or CSVT with a factory alarm.
The LED that flash beside your clock is the PATS. Passive Anti-Theft System. All the V6 have that feature. That mean that you have an electronic key.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
Look at this thread:
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=724569&fpart=&PHPSESSID=
...for pictures of what the programming connector should look like.
1995 Contour GL V6 ATX T/C 1986 Mustang GT 5.0 2000 Windstar LX
