#1248655 04/17/05 02:29 AM
Hi, I went out and looked at my car today for idea's on where to mount a B&M Trans cooler.
(99 Contour SE 2.0 Zetec)
Please correct me if i am wrong here. From under the vehicle i see the radiator, the condensor and what i believe is a small trans cooler .
It is in front of everything and looks like it is connected to 2 lines going to the tranmission. The part looks as follows, the 2 lines are connected to what looks like a 2 pass thingy, lol. It has 1 tube that curves around to a tube with fins on it.
So basically, a finned tube- curve -tube under that to the tranny lines.
Is this an after market tranny cooler or a stock one? Or is it even a tranny cooler at all?
Please help, i am very confused about this.
Thanks
99 Contour SE Zetec 2.0 ATX My Ride
#1248656 04/17/05 03:34 AM
F
F
What you are actually looking at is the power steering cooler, the trans coolers for the contour is built into the radiator. I mounted the trans cooler on the drivers side, I had to squeeze the thing to get it between the radiator support and condensor but it fit. Twelve thousand miles and I havent had any leaks or problems with the placement.
#1248657 04/17/05 06:19 AM
Heh... you're from Waukesha. My ex g/f back in Iowa's brother lived there... found out I could make it from near Davenport to Waukesha in my 90 Sentra on 1/2 of gas (that's like 6 gallons, btw). On a seperate trip made it from Waukesha back home in 2.5-3 hrs doing 90-95 the whole way back (in my 89 Grand Prix).
Took me a couple trys to be able to say 'Waukesha' correctly.
Goin' Round Traffic Circles @ 50Km/h!!! \m/ -- 1998 E0 SVT #2119 of 6535 \m/ -- 2003 Sentra SE-R Spec V
#1248658 04/17/05 12:49 PM
Thanks, i thought i read in a few threads that the stock trans cooler was built in the radiator.
I guess i will have to look at it a little closer and try and fit it somewhere. They make this 1 tight fit on the Tours.
Thanks again,
#1248659 04/17/05 01:33 PM
CEG road warrior
CEG road warrior
I will take a pic of where mine is mounted.
#1248660 04/17/05 01:53 PM
Great! That will help alot
Thanks
#1248661 04/17/05 02:10 PM
CEG road warrior
CEG road warrior
Just uploading the pics....should be a couple of min.
#1248662 04/17/05 02:14 PM
CEG road warrior
CEG road warrior
#1248663 04/17/05 02:39 PM
Thanks for the pic !
Now i have to get out there and get it done.
Thanks again,
