#95127 05/04/01 04:42 PM
I am going to take on the project this weekend and was wondering if anyone has run into problems of other suspension parts being worn. I don't want to get half way through it and find something else and not have money for it. by the way i'm installing konis with ground control coilovers
thanks
96' LX (de-badged,konis,ground controls,injen intake,hose techniques kit,gauge pod,phantom gauges) more soon...
#95128 05/04/01 05:13 PM
One thing I noticed is that it took ALOT of beer to get the job finished.
Just call me Judge.
People suck.
Life begins at 170mph...until that point it is just boring.....
#95129 05/04/01 05:15 PM
Master P
Master P
I found that my front sway bar bushings were worn out when I did mine. They're still worn out.
#95130 05/04/01 05:26 PM
Too bad I was the only one drinking, waterboy!
Oh and beer cleans garage floors pretty good!
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#95131 05/04/01 05:45 PM
top
#95132 05/04/01 10:52 PM
It's easier than you think... Just remember to pull the bottom ball joint out and remove the lower tie bars(for the rear) and it's simple!
Dom
#95133 05/06/01 11:55 PM
H
H
I ended up snapping two pinch bolts the one that holds the strut in the upright/bearing carrier, buy 4 new bolts before you start and be prepared for blood sweat and pain ! If you need the car to go to work etc. Tackle one end per week end front or rear good luck wink
