Q
Qbert Offline OP
Q
http://www.teamfocaljet.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=57&t=000015
This is pretty bad. As far as I can tell from the write up is the inner liners of the gas tanks are degrading at around 30Kmiles. My friend just had his focus in for a stuttering problem under accelaration, he has 25K on his. This is a big issue and Ford is going to bite the big one on this. That is a lot of cars to be replacing gas tanks and fuel pumps on...I wonder how much it has effected the engine too!
frown frown frown frown frown
Good old quality control!
Current Cars:
2000 CSVT #398 / 2150 - TRed
85 CRX si with a suspension harder then Ron Jeremy on Viagra.
9
9
we've already had our focus in twice for recalls
This is getting pretty sad.
i hope it doesn't affect the engine at all.
we have 18000km on our 2001 zx3
speed is adictive, the faster you go the more you want.
2
2
Good old, "lets get the cars out there, and make sure it's cheap to make". "Let the dealers worry about problems." "They can get truck or SUV if they don't like it." shocked
Jac the knife's guys were in such a hurry to get the Focus on the market, they overlooked too many things.
2000 SE fleet, V6, ATX, ABS, no spoiler, T-Green/tan. Built 01/2000 in MO.
Added 12 spoke factory SE rims, K&N. Biggest mod: ESP Plan!
That is just rediculous. I mean would not you test any new material used in a gas tank for stability in the setting of petroleum??? So a little bit of dissolved plastic gets injected into your engine every day. I will say its a big deal :rolleyes:
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
Sure, and Ford should have tested the fuel flapper valve on the Contour too. Somebody should lose their job over either of those problems, but the sad thing with Ford is that you pretty much have to steal from the company or have sex in the office to get fired. (Those were the only two things I ever heard that got a regular Ford employee fired when I worked there.)
