Posts: 289 |
OK I got mine today, and I have a question. Well first of all are they really that big, cause I remmember seeing H&R springs on the web and they seemed to be much smaller, but Eibach are pretty big compare to those. Just want to make sure I got the right springs. Also they say on their site they are suppose to work with stock struts, but thats not true right? I am planning on replacing mine anyway.
Thanx
98 SE V6 ATX 15" EPIC Chrome Rims Aftermarket Foglights GTO Blackouts Alpine 7840 Pioneer 6895 In back, Pyles in front 2 MTX 6000 10" Subs MTX 220D AMP Limo Black Tinted back windows KKM SVT Exhaust SVT Grill AIM: CoOlVaD14 ------------------------- Coming soon.... SVT Kit
Posts: 2,906 |
I thought the same thing when I got mine. So you got the right ones. ------------------ Black E0 SVT #2239 Mirko Racing-K&N Intake/Res Replaced w/str8 pipe Silver accented interior/White HVAC panel/Silver-Carbon fiber pedals Chrome painted grills/Black-Silver Frt Ford emblem Sony Explod Audio stuff Koni/Eibach suspension MOVIE LOGIC: "All bombs are fitted with electronic timing devices with large red readouts so you know exactly when they're going to go off."
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 2,683 |
Mine have been working flawlessly for the past two years on the stock struts!
Howard 1998 Silverfrost SVT #1612 June mods: 17" ADR RS Limited Limix Wheels with 215/45/17 Yokohama AVS Sports
Posts: 2,177 |
Ditto with Journie!! But the only prob I have is that the rear is lower than the front so my damn tires rub!!!!
Garrett Stines (sponsored by Duct Tape) '02 WRX Sedona Red Pearl ...I Have a Turbo... Trolling it up in SO. Cal! SOLD IT'99 SVT Silver Frost~#925-2760~01/21/99 THE RIDE!
Posts: 517 |
smp,
do you have bigger wheels 17's or 18's or is it rubbing the stock wheels and tires? I'm planning to get my eibachs installed next week, and i sometimes have people in the back seat or stuff in the trunk, will it rub my stock wheels & tires? if it will i might have to think about getting a lower profile tire.
------------------ 2000 SVT (silver) #1529 of 2150 ------------------- resonator removed K&N fog light mod Xenon foglight (autotoys) Nokya Xenon headlights painted sail panels, rear reflector and lower valance alluminum mesh grille
2000 SVT (silver) #1529 of 2150 ------------------- yeah...its modded
Posts: 1,041 |
Ive had my Eibachs for three years now with stick struts, (i know i know). I have 17" rims and yeah you'll get some rubbing but Eibachs are great. Try shaving off some of the wheel well inside. THis will help a little with clearance for the tire.
------------------ Silver 98 SVT Contour Eibach Pro Kit Niche Pultec 17"x7.5 Toyo Proxes 215/17/40 Shaved Wheel wells 19mm Front Sway 21mm Rear Progress Tech. Superchips Auto Meter Pro Shift Light Extrude Honed Stripped Resonater Street Scene Free Flow Exhaust Injen Tech Cold Air Intake Hose Techniques Red Kit MOMO shift knob/pedals/seat belt pads Oki Doki Signs Vinyl Graphics Clarion/Sounstream/Kicker
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 2,906 |
My tires are tucked underneath the fender line and I have had no rubbing. I have 205's on there now and will be upgrading to 215 soon. I have not rolled the fenders at all. I don't think there should be a prob since there is still room for 215's.
Posts: 151 |
I also have the Eibachs and have 17x8 Borbet Type S wheels. I run 225/40/17 Nitto 555s and on the rear they do rub slightly with weight in the rear. But the traction is unreal.. Rod K.
------------------ Rod K. 98 SVT Contour E1 #5782 93 Lightning #1529 13.68 @ 97.82 so far...
Rod K. 98.5 SVT Contour E1 #5782 15.50 @ 88.92  93 Lightning #1529 13.27 @ 101.55 on motor. 12.52 @ 107.28 on 125 shot.
Posts: 114 |
I have a set of 17" Kosei Racing Seneka's with 215's on and no rub unless I giver hell with 4 or more people in the car then the rear will rub on the plastic liner a bit. But this is IMPORTANT get your car re-aligned after you lower your car. You will need to readjust your toe-in. Anyone that says otherwise doesn't know his a$$ from his elbow. Usually whoever puts the springs in will align it for you unless your going to a friend who will do it "really cheap". The previous owner of my car decided not to re-align and I ended up buying two new front tires out of the deal, don't let this happen to you.
Posts: 2,177 |
Ok I have a set of 18"s with a 225 40 tires. Even with my fender lips rolled I can still rub the hell outta my back end. Thats why im gonna get a set of H & R's for the rear... ------------------ Garrett Stines (sponsored by Duct Tape) '99 SVT Silver Frost~#925-2760~01/21/99~painted Rear valance silver~18" Masitaly's~Kumho Rubber~Eibach Springs~OMP Strut Bar~Carbon Fiber sail panels~SCA CAI~K & N dual stage filter~Series 5 superchip~Bosch +4~SVO Tach~B & M Edge Short Shifter~Richbrook Knob~Pedals~Razo Dead Rest Pedal~Side Markers~lots 'o Carbon and Chrome~Boomin Tunes~and more THE RIDE!
