#1244179 04/12/05 04:54 PM
I
infratl Offline OP
I
so, does anybody know what the difference is? i suspect max ac to be colder than ac, but what does it actually do that makes them both different?
#1244180 04/12/05 05:03 PM
Max AC is the recirculating mode, that is it continually recirculates the air inside the car, bringing in no fresh air. AC by itself justs cools fresh air that is brought into the cabin. MAX AC can be used to stop unwanted smells from entering the car, it can also be used to cool the car more quickly when it's really hot.
#1244181 04/12/05 05:06 PM
Correct!
Adrian 1999 CSVT, Tropic Green #1925/2760 Bosal Exhaust / B&M Shifter / Quad projector 4300K HID
#1244182 04/12/05 06:00 PM
I
infratl Offline OP
I
thanks for the info.
question. i probably shouldn't be asking this here, but doesn't anybody know if there's a mod to where u can have an independent switch to switch from fresh air to recirculating air... in case i want to do that with the heat on and without turning on the a/c?
#1244183 04/12/05 06:05 PM
It would be hard on our cars. You'd have to determine which circuit controlled the recirculate mode and tap into it with a switch. On other cars, even ones less expensize than ours, there is a seperate recirculate button that allows you to select recirculate in any mode. On these cars, there is no MAX AC position, but you can change the mode to AC and then press the Recriculate button to activate MAX AC. Ford didn't see it necessary to put such a switch on our cars, and so we only get recirc in MAX AC.
#1244184 04/12/05 06:12 PM
I
infratl Offline OP
I
man, that's a big thing i hate about the contours. i used to have a civic before i got the svt, and it had a switch for the recirculate and a switch for the a/c. so i could have air blowing on defrost without it automatically kicking on the a/c, like the svt does.
well, i guess it's just something i'm gonna have to live with.
#1244185 04/12/05 06:24 PM
Didn't some guys figure out how to how to mess with the recirculation?....Maybe on the old boards?
I know some guys have put in a switch for the A/C when using defrost.
1998 Mystique LS: -2.5 Duratec ATX -Vibrant White -------------------- =Pics= =Info=
#1244186 04/13/05 01:44 AM
on my bronco the recycle/fresh air door is controlled by a simple vacuum canister, if its the same on the tour you could easily make a switch.
1994 Volvo 850 Turbo 1992 Bronco Eddie Bauer 5.8 E4OD 1998 Contour GL 2.5 CD4E 2001 Montero Sport Limited 3.5 Auto 2002 IS300 3.0 Auto See My Cars
