#94749 04/30/01 04:01 AM
X
X
Which one is better performance wise Straight pipes or Y-pipes?
Check out my sig
Sincerely
Merlin
Kansas City CEG
99 SVT Black #1210
1/4 15.564@ 88.24 mph
KKM intake/Custom Exhaust/Fog light mod /20%tint Dyno=163.8HP,148.5FT/LBS
CHIP Dyno'd 159.3hp 154.4tq 1/4=15.502@88.95
Sho off road Y HP=171.6,TQ=160.1
Merlin
281hp 324tq
Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
2
2
At our last dyno night we had a guy LOOSE 9hp and 6 lbs/tq from the off road y pipe.
Zach
2001 VW Golf GLS 1.8 Turbo
220hp/260tq
Porsche Cup 3s rims w/225 45 17 tires
Oettinger Grille, Votex Rear Spoiler, and way more mods
Lemme see some proof...
2000 SVT #674 - Check it out!
On a tour????
Zach
Merlin
281hp 324tq
Merlin- I see you love your off road y-pipe. Is yours aluminized or stainless. Thinking of getting one for my 95SE. I run gutted cat and SVT cat-back minus resonator. My current setup is raspy for less than a minute till warm. Does OR y-pipe make system sound more raspy?
Just found your discussion in mods section. You went aluminum. I am a bit worried about the noise.
[This message has been edited by Barry (edited May 01, 2001).]
Barry-2002 WRX-Sedona Red Pearl
K&N Air Filter- 225/50-16 SP5000's/Cusco Front Crossmember Brace/Borla Exhaust
JoeP Manual Boost Controller/Kartboy Solid Rear Endlinks
Samco Intercooler Hoses
Silencer Removed
Will Always Be Immaculate
I have the catless as you saw. It is raspy on cold start, but after that,Great. My system was not raspy with I had the stock cat and res only. Again when I switched the y's, that is when I gained cold start raspyness.
I just have a resenator. It makes a big difference is the raspyness of stock mufflers only vs res only. I would personaly change the setup with res only. Then if you don't like you can always add highflow mufflers to help out.
I personaly think that you will have less cabin noise with the res than just the mufflers.
Is yours !!!!!!!aluminized!!!!!! . Thinking of getting one for my 95SE. I run gutted cat and SVT cat-back minus resonator. My current setup is raspy for less than a minute till warm. Does OR y-pipe make system sound more raspy?
Sincerely
Merlin
Merlin
281hp 324tq
Geez, there is just so much info about all this on here! 3 cats, 2 mufflers, a partridge in a.....
I've got to get a replacement cat put on soon, so I've been thinking of losing the rez and running a straight pipe when the muff man puts it up on the racks.
Something tells me the noise and rasp will drive me nuts, but I'm about to buy a second car soon anyway, so I can stand a little racket. But can anyone tell me exactly HOW MUCH racket not having a resonator will bring me? I guess I could always crank up the stereo, though....
-Tim, '95 GL 2.5L, 5-speed.
-Tim, Former crush: a '95 Contour GL 2.5L, 5-speed. Current love: 2001 Toyota Tundra SR5 King-cab 4x4.
Right now i have stock y pipe and bassani cat back. theres no raspy noise. I had the sho shop cat less y pipe on and noticed a performance loss from not enough back pressure. There is a raspy noise but its not that bad or loud. I like how the bassani sounds with stock y pipe then cat less y pipe though. I'm not sure if you get a chip custom burned for no cat if there would be a performance loss, anyone know?
99 Silver SVT
blue headlights
tint
replaced sterio & speakers
kkm intake
bassani cat back
B&M Edge Short Throw Shifter
OMP Strut Brace
GO WINGS!
99 SVT Silver w/ Blue Stripe with some mods. mike4420@comcast.net
"To each his own"
A lose? Well did you have it dyno'd??? Give me more info. I gained soo much that I don't see how. Just wondering.
99 Silver SVT
blue headlights
tint
kkm intake
bassani cat back
OMP Strut Brace
Sincerely
Merlin
Merlin
281hp 324tq
