tbarney Offline OP
I'm looking to install a front strut tower bar. I know it won't add much performance, but I think it looks good.
With the searching I have done, a lot of people seem to recommend the STB from OMP, but that requires drilling. The SHO strut bar doesn't require any drilling but is about $50 more. Since a STB isn't much of a performance upgrade, I don't expect to get much out of it, but will either function better than the other?
I'm assuming that the SHO bar uses the existing suspenstion bolts to fasten it to the frame, do I run the risk of snapping the bolts with the SHO bar, while the OMP bar would us it's own mounting hardware....Any suggestion here would be appreciated.
-Tom
99 Sport ATX 1 owner, 94k Mobile 1 since 1k Mods:Sony MD Player, Sony XA-300 expansion unit, Sony CD Changer, XM Radio, 350Watt Alpine Amp, 2 10" Subs, Remote starter, glow gauges, K&N filter,OMP Front STB, SVT Exhaust(no res.)
Yes you do run a great risk of snapping the bolts off the tower. That's why sho-shop sucks! Deff. get the OMP becuz even though it drills, it won't snap under a greater pressure... The OMP is worth it.
I HAVE THE OMP BAR. IT'S EASY TO INSTALL. THE DESIGN OF THE MOUNTING AREA SPREADS THE LOAD OUT. I PUT SOME CLEAR CAULKING INTO THE HOLES AND ON THE THREADS OF THE SELF TAPPING SCREWS TO HELP SEAL THE HOLES.I HAVE HAD IT FOR A LONG TIME NOW WITHOUT ANY PROBLEMS.
"we aren't punished for our sins, but by them" 2000 se sport tropic green/gray leather. V6,svt body kit and E1 wheels/Avon tech m500 rubber, many mods. 2003 Eddie Bauer Explorer V8 2001 Suzuki Bandit 1200S 1996 Mercury Sable
DID YOU MEAN TO TYPE LIKE THIS? OR ARE YOU TEE'D OFF ABOUT SOMETHING? J/P
tbarney Offline OP
Sounds like the OMP is the one for me. Thanks for the suggestion about putting caulk in the holes.
-Tom
