Viewing the Energy Suspension website, I see that greasable sway bar bushings are available. However I believe these have to be bought from a reseller....the ES site has no order info (so I assume they are a wholesaler only).
Anybody use these ? Anybody know where they can be ordered?
Seems like the solution to often voiced complaints about sway bar noise.
98 SVT T-Red. 17" Borbets w/GY Eagle F1 GS-D3's, Koni/Eibach setup, urethane suspension bushings. Aussie Bar. Battery in trunk, open K&N Filter. B&M Shifter. Gauge pod w/ volts, oil pressure, oil temp. Sparco drivers seat, Schroth harness belt
