Posts: 110 |
http://www.cardomain.com/memberpage/678557/4New control arm setup equipped w/ Delrin bushings. Just need to drill and tap grease fittings. Then will put front suspension back together.
Posts: 3,732 |
how much would you sell the parts needed to use those bushings?
Russell
Oval Port 3L Nearly Done
Posts: 3,335 |
Originally posted by Russell-3L: how much would you sell the parts needed to use those bushings?
Or let us into the secret of where you got the bushings/sleves and perhaps even measurements on the new pins/spacers?
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 3,887 |
Cool beans man nice work. Did you heat treat those pins? They almost look like they where heat treated.
06 GMC Sierra 2500HD Dmax/ally
06 Pontiac G6 GT
05 CRF250R
FOR SALE 06 KX65 with riding gear $2700 obo
Posts: 4,970 |
Originally posted by ExDelayed: Originally posted by Russell-3L: how much would you sell the parts needed to use those bushings?
Yes, either would do! I need a to do something about my POS LCA's before I get my car tuned
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 862 |
that is awesome. I am holding out for someone to produce a kit that does this mod before I fix mine.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
Posts: 609 |
THAT is how Ford should have built them in the FIRST place! I don't know how that would have cost much, if any, more than the stupid design they came up with. Seems a lot simpler than the dumb oil-filled rubber molding and the other junk they put in them.
Sooooo, when can we buy those?  I've got my old ones here I could send out for rebuild...
Marty
98 SVT, Black, No. 786, May 7, 1997.
K&N, MSDS, Xcal2, Tint, Antennas, Big Gulp(R)-Sized Cupholder, Rear Dome Lt., Koni/Eibach, DMD, Pre-98 Sails, Brake Cooling Deflectors, Sidemarkers, Etc.
147K+ Miles
"Get the Door - It's GrooveNerd!"
Posts: 3,335 |
Originally posted by GrooveNerd: THAT is how Ford should have built them in the FIRST place!
Except Ford would have still used rubber bushings. Delrin is too stiff for a 'family' car.
But if they had done it this way, there would be bushings we could buy to easily drop in to replace the rubber.
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 65 |
Are you teasing us by showing this to us? Are there any possiblities of manufacturing your setup?
Thanks
Posts: 110 |
The ones shown in the pics are just prototypes. We're not to sure about mass producing these as of yet. When the car is finished and the new pin system is proven to work we'll finalize drawings and work up a cost to manufacture.
