Posts: 142 |
Alright guys, I finished up the install of the SVT UIM on our Cougar and when we started it up the engine is rocking (front to back) pretty bad and there's a loud tapping which almost sounds like bad lifter tap.......the problem is I didn't touch anything except the UIM, LIM (to clean it) and the other misc stuff to get everything out.
Any ideas what could be causing this? I replaced all of the gaskets, but I can't think of anything that would have been done to cause the tapping......I'll try and get a sound clip here in a sec.
--Adam
Posts: 142 |
Here's a video (the engine wasn't rocking as bad as the first time in this though. It's 4MB http://www.gforceauto.com/coug_tap.asf (Right-Click, Save-as) --Adam
Posts: 142 |
Okay. update, we reset the ECU and now that tapping has quieted a bit but now there's a popping when you rev the motor a bit.
--Adam
Posts: 432 |
sure you didnt drop anything down there why you were working on it?? thats what it sounds like.
Posts: 799 |
I have taken the UIM off about 20 times when I was working on my car, no problems. I agree with the above statement, did something fall down the LIM ? Sounds like something got into the motor. Did you hook up all the hoses including the brass fitting one under the intake piping, I forgot that one sometimes. Good luck with it. -B.
1998 SVT With a few mod's
RACECAR IS RACECAR BACKWORDS !
#970 of 2395 Black/blue
*****FOR SALE*****
Posts: 142 |
A foreign object would have almost immediately shattered a piston. Not to mention I'm very careful when it comes to intake parts like this.
--Adam
Posts: 4,292 |
did you accid unhook a plug wire?...sounds like either that or you have bad vaccum leak...
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 142 |
We just started it up again and it is all better, but thanks for all the help.
--Adam
Posts: 1,176 |
I'd be willing to bet you dropped a small screw or bolt....As you run the engine it escaped out through the exhaust or disinigrated...........
Bob
Posts: 1,356 |
I guess thats a possibility, but I doubt it as it would've had to have been a pretty small screw or washer or whatever.
It could've gotten embedded in the cylinder... That happened to my brother in his old mustang.
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
