#94475 04/25/01 04:03 PM
Does anyone here run a low temp thermostat? If so what degree? Mustangs use these quite often and I use one on my vette (came with the chip) but i never see mention of it on these pages....What's up with that?
1984 Corvette FOR SALE
Red/Red Leather
Perfect Condition
2000 SVT Contour
Black/Blue Surf
KKM Tru-Rev
Resonator replaced w/ 2.5" DynoMaxBullit
Parking/Fog Light Fix
Aluminum Intake pipe
G-Tech
Valentine 1
Soon To Install:
MSDS Headers
Catco Hi Flo Cat
motowngrip@earthlink.net
1984 Corvette
FOR SALE
Red/Red Leather
36,000 Miles
2000 SVT Contour
Black/Blue Surf
KKM Tru-Rev
B&M Edge Shifter
Gutted Pre-Cats
Heavily Ported Y-Pipe
Aluminum Dead Pedal
BN Motorsports HVAC Panel
Hoodliner Removed
G-Tech
Hardwired Valentine 1
Soon To Install:
Real Premium Sounds
MSDS Headers
#94476 04/25/01 04:48 PM
F
F
Our cars are so computer controlled that a low temp thermostat would probably create problems and have absolutely no performance gains. It would constantly change the air/fuel mixture trying to change for the colder temperature. Try some Redline Watter Wetter or 40 Below if you want to make it run a little cooler safely. These are both additives for your coolant that let it dissapate heat better.
Chad Williams
chad5160@usa.net
'99 SVT Frost Silver #812 of 2760 Born on Jan. 12, 1999
Quite a few mods *) and some big tunes. Roaming the streets of Denver blowing exhaust at imports!
Chad Williams
chad5160@excite.com
#94477 04/26/01 06:00 AM
Exactly what FLuiDSVT said.
Computer stays in closed loop mode until it reaches proper operating temperature.
On the water wetter. You won't see any real difference unless you run atleast 60% water and these engines (V6) run fairly cool to begin with. It's more beneficial to a forced induction car to help reduce temps while under boost.
2000 SVT #674 - Check it out!
#94478 04/26/01 03:36 PM
N
N
What is the normal operating temp for a duratec i find mine to be quite hot.
1999 rio red mtx cougar
#94479 04/26/01 07:35 PM
V
V
I run a low temp. stat. Low temp stat do not "makes" power but it keeps power from being loss due to heat soak. This topic was posted before.
#94480 04/26/01 09:06 PM
IT DOES NOT keep power from being lost! The engine will reach proper operating temperature regardless of thermostat installed. (barring cold weather - in cold weather a low thermostat will actually hurt the car a lot!) It will just take longer and stay in limp mode (closed loop) longer. Both of which are BAD things...
Not only that, but the highest period of engine wear is from inital startup until the engine reaches proper operating temperature... (This is why it's recommended to let the car idle for a few minutes before driving off) So you are extending this time of very high engine wear! Not a good idea.
According to the manuals the thermostat opens around 185 degrees (+/- 3 degrees) for the V6. 192 (+/- 3 degrees) for the I-4.
