Check to make sure your radiator is clean on the outside in front of the fan. I know this is obvious but many people forget to check. Also check your condensor to see if the fins are bent where there airflows in through the bumper at the bottom.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
