#1235561 04/04/05 06:04 PM
Ok folks this is how its is going:
Replacing Passenger side lower ball joint
Ground off 3 riboits
loosened the pinch thingy (holds Top of ball joint)
Tried to pry,hammer and cussed alot but nothing wants to come loose.....
Any Ideas ?
#1235562 04/04/05 08:21 PM
the lower ball joints are a real pain in the a$$. I removed the entire lower control arm and used a cutting torch for the rivets and a air chizel to punch out the bolts that were ground off. From what you wrote it seems like you are trying to do it on the car. If you take the lower control arm into a mecahnic or machine shop they shouldn't charge much to finish up the job for you. I just don't think there is any way that a hammer and punch is going to have enough force to get that thing outta there. Good luck and PM me if you have any other questions.
98.5 Black contour // A.K.A. Frankenstein 3L Oval port swap W P&P // SVT UIM, LIM, & Cams Torsen LSD // Dual Friction // KKM // Poly Mounts // ?Mystery Mod? // Actually Running! 205 hp @ 6500RPM 180 tq @ 4250RPM
#1235563 04/04/05 09:34 PM
depending on year and milage just buy a hole new control arm, you get new ball joints and bushings all at once
