Posts: 1,145 |
well, it finally kicked the bucket, been expecting it with the low voltage reading i have been getting at the battery. My question is should i go ahead and get a 130 amp alternator and upgrade the the wiring between the bat and alt with some 0ga and the batt ground with some 0ga -or- get an upgraded alternator, the 200 amp alternator and do the same wiring upgrades as above. let me know what you guys think because i need to get the thhing replaced as soon as possible.
98.5 Black SE ATX
Posts: 4,292 |
have fun if your doing it yourself!!!
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 1,145 |
yeah i know, i will gonna be a real PITA to do, what happened to the how-to in this section, some pics are missing, i need those pics to do the alternator change
98.5 Black SE ATX
Posts: 9,602 |
If you have a big system then get the 200 amp alternator. You "need" it. If you don't then... Don't...  FYI - The 200 amp alternator will rob more HP and wear out quicker.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,145 |
no i dont have a very powerful system at all. all i have is a kenwood deck. it only puts out 200 watts. still got the stock speakers. the only planned future upgrades that will put a drain on the alternator would be some 220watt speakers all the way around. and then possible a small amp and sub, maybe 400 watts, if that.
98.5 Black SE ATX
Posts: 1,145 |
and a side note, does anybody know when knuknoceptz will have the positive battery terminals again, i need one since i plan on re doing all the wiring
nevermind i found out when they should have them back
98.5 Black SE ATX
Posts: 1,145 |
update on the alternator, got the alternator out today, was surprisingly easy, went and got it tested and it was only putting out about 12 volts if that. decided to go with a 200 amp alternator because i can get it new for the just a little more then the regular 130 amp alternator, also it has a lifetime warranty just like the 130 amp im getting the alternator shipped for around 220. if anybody else wants to get one, you can get them from here, the website lists them as 219.99, its all the way at the bottom, it is the 3g 200 amp.
98.5 Black SE ATX
Posts: 6,791 |
My second alternator in under a year just died!
Posts: 1,145 |
what are you doing with them, running a city?? hope it was under warrenty, other wise you might wanna look into the one im getting
98.5 Black SE ATX
