I just bought Autolite Professional spark plug wires and Autolight Double Plat sparks and I got the plugs in perfectly and i went to plug in the spark plug wires in (autolites) and the clamp connectors that have a little metal ring that connect to the coil pack (i think thats what its called) but they do not fit right. I had the factory Motorcraft in and these aftermarket plugs will not fit correctly. What should i do? Return the plugs for a different set? Thanks for your help!
Midnight Red 95 Contour SE 5 speed, fully loaded. kkm M.A.F. adapter w/ K&N ru-3530, single Magnaflow muffler w/ no res. 2.25" custom catback exhaust, grafite painted stock 95 SE rims on bfgoodrich touring T/A's, 35% window tint around.
