Posts: 100 |
I just got my smog-check letter from DMV and it says I have to go to a 'test-only' center which sucks because they do the same test but charge more. Anyways I found a place that'll do it for $48 [with $10 coupon] in Santa Ana [Orange County]. Anyone from So Cal know of a cheaper place?
One more thing, I have a check engine light on. I only have one code - P402 [low EGR flow]. I don't know if I'll have time to clean out the EGR from all the carbon this week [smog's due on 04/08] so you think there's any way I can pass with the one code? Any suggestions!? Thanks
Contour '97GL 2L ATX, ~100k
Pioneer sound system
A few unintentional scratches on the back and a rebuilt tranny
Posts: 2,469 |
Originally posted by lovemycontour: so you think there's any way I can pass with the one code? Any suggestions!? Thanks
Nope they wont even run the car. you have to get that cleared before they test it.
Posts: 100 |
Thanx I'm looking into cleaning the upper intake, but I can't find the tutorial they used to have on this site. Well I have a week to figure it out.
Posts: 1,322 |
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760.
"Many posted questions are answered by farm boys"
Posts: 3,045 |
which place in santa ana are you going to? i ask cause thats where i live. the last test only place i went to iirc charged $49+$8 fee+tax just earlier this month.
edit-no way in hell you are gonna pass with a cel.
00 black/tan svt, #2052 of 2150, born 2/1/00
formerly known as my csvt
"Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
Posts: 411 |
Find someone to clear the CEL first. Make sure your car is at normal operating temp (re: drive around a little before you get to the inspection station) and you should be OK.
Where in Santa Ana is it?
-Chuck Dienzo
Black 98.5 E1 SVT
#5022 of 6535
Born on March 16, 1998
"If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
Posts: 1,322 |
Originally posted by vudusvt: Find someone to clear the CEL first. Make sure your car is at normal operating temp (re: drive around a little before you get to the inspection station) and you should be OK.
They will know if you erase the code w/out fixing the problem.
I had the same code on my SVT, replaced the DPFE, drove over a hundred miles, multiple start-ups etc. Took it back and some of the IM monitors read "not ready" you need to fix the problem and ensure the IM monitors are set. The Actron code reader I use will only let you know if the monitors are functional, you also need to know that they are set.
On DURATEC engines my experience has been that the DPFE is the fix for P0402, and cleaning the passages cures the P0401. I'm not sure about ZETEC engines. do a seacrh or get in touch with some of the ZETEC guru types.
You can also get an extension, just tell the DMV you are having problems, they gave me two months. While you are there pay your registration, that will make things go faster when you return.
The test only stations are also more likely to have problem with after market intakes etc.
Posts: 100 |
Yea I'm going to that place in Santa Ana which charges $48 + $8 for certificate [http://smogtips.com/business_detail.cfm?VendorID=7589] but I got a $10 off coupon online from smogtips.com
The code is there but the light somes on and off [prolly the sensor after all then]. So I'll try to pass and if it doesn't [and it prolly won't] I'll come back for a free retake - I live 10 mins from there.
Posts: 100 |
I PASSED my smog today at that Santa Ana place @ Main street... The check engine light goes on and off from time to time but that time it was off and I PASSED [I'm 100% sure the code it still there but the light simply is off - it'll come on again!!!] HELLZ YEA!!!! ...my girlfriend's Jeep didn't pass though [we did both ours on the same day] - she's got a LOT of problems on her car
