Originally posted by sesomba:
I have a 99 contour SE and was wanting to know how to remove the back seat so I can run power wire to hook up amps and speakers.
Thanks for the help,
Brad
First to remove the bottom bench you have to lift forcefully on each corner to unclip it from the body. Then you push it back towards the trunk and then pull up. Then just slide the wire under the seat back and your set.
HTH
Chris
