#1229318 03/29/05 05:13 PM
After replacing both LCA's, and installing the focus shift tower, my car makes creaking noises while turning, like something rubbing on something else. Also, the camber is off. I don't know if it's negative or positive, but the tires look like this from the front / \, just not that exaggerated. Is something broken? I have a stock suspension with 150k on the clock. I'm clueless and desperate. PLEASE HELP!!!!
98 CSVT silver frost mods: 893 fogs, 2 12" free airs, alpine HU future mods: LED taillights, In door 8's...who knows?
#1229319 03/29/05 05:21 PM
have you gotten an allignment?
~Alex
#1229320 03/29/05 10:59 PM
I haven't gotten an alignment yet, but I don't see how they can adjust the camber. It's not like they can shorten the LCA's. ??
#1229321 03/30/05 03:11 AM
Can't without aftermarket camber plates. I think when they change toe, that can change camber some, but can't change camber alone without the plates.
#1229322 03/30/05 06:44 PM
Some negative camber is normal, and at 150k miles, your car may be sitting a bit low, as well, on the stock springs. (They won't lose rate, but they may sag a bit over time.) As the car lowers, negative camber would be more pronounced.
I'm not sure about the creaking. Could be a number of things... Worn struts? Bad strut bearing? CV joints?Somebody else should chime in...
Function before fashion. '96 Contour SE "Toss the Contour into a corner, and it's as easy to catch as a softball thrown by a preschooler." -Edmunds, 1998
#1229323 03/30/05 06:49 PM
measure it and get a number. If it's small enough, then you're a-okay. Neg. camber, at least a little, is good for handling in most cases.
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
