Posts: 267 |
WellI might not be the first but I definatly learned the hard way. I bought a set of Matrix Coilovers for a 99-00 Cougar which I cross refrenced to fit on the CSVT. Even the GC's say they will fit a Cougar according to Sp Motorsports. Anyway, the kit fits but with one problem, the top plate that sits on the inner upper strut mount is TOO THICK and does not allow enough strut thread to stick through to stick the top nut back on under the hood. Everything else fits fine, I didnt get around to the back yet but I am assuming they will have a similar problem. My question is, Can I buy just the GC fronts and not a complete kit?? I have Eibachs on now and wouldnt mind the front just a little lower for a nice raked look.
Jonathan
Posts: 4,292 |
yeah you can buy just the fronts...if you go to sp or cta? they list the prices for front or back or together..so the kit didnt work? maybe you should see if you could buy the plates from the gc's instead of a whole new kit?
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 10,015 |
You could counter sink the hole in the top hat with a bigger drill bit to suit the diameter of the strut rod and thus allow more thread through.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 713 |
Originally posted by Stazi: You could counter sink the hole in the top hat with a bigger drill bit to suit the diameter of the strut rod and thus allow more thread through.
that is what i did worked fine
98 svt sil/blu 3.0 oval heads full P&P, msds headers,bat kit,2,1/2exhaust 30 inch glasspack and 2 spintech mufflers 14.78@94mph
with my mechanical arm i can shift gears in less then a twentieth of a second for sale $7000
Posts: 267 |
That will work....thanks Stazi!!
Jonathan
Posts: 267 |
Originally posted by lowbudgetracing: Originally posted by Stazi: You could counter sink the hole in the top hat with a bigger drill bit to suit the diameter of the strut rod and thus allow more thread through.
OK...do you know what size and do you have any pics I can see to help?>
Jonathan
Posts: 21,197 |
What do you mean, "what size?" Whatever it take to drill them out a little larger.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 10,015 |
Originally posted by jjhirsch: Originally posted by lowbudgetracing: Originally posted by Stazi: You could counter sink the hole in the top hat with a bigger drill bit to suit the diameter of the strut rod and thus allow more thread through.
It'll be the same diameter or a smidge larger than the strut rod diameter.
AUSSIE ENDLINKS $70
Posts: 4,292 |
ughhhhhhhhh got my kit lastnight...but it didnt have the adjusting wrench...does anyone know were i can get one of these??
Posts: 10,015 |
AUSSIE ENDLINKS $70
