Posts: 5,810 |
Originally posted by TourDeForce:
Here's the thing. You're assuming that there will eventualy be some SVT cams bolted on top of those heads. If you don't have the cams, the regular Duratec 2.5 cams just don't take advantage of the extra flow of the SVT heads. The regular cams will fall flat at around 6k rpm rather than continuing to make power up to/through red line.
Actually I'm not assuming anything. The part about standard cams not taking advantage of the heads is not an accurate statement.
It is especially critical to have good flow in order to make the most of cams that aren't optimized for high rpm flow. Since the valve timing is less than optimal for flow above 5500 rpm then you want to have as little resistance to flow as possible so you can get more air in. If what you are implying is true then there would never have been anyone with small block V8's porting and polishing heads to get extra flow....and we all know that's a critical improvement for those motors.
The cams for the SVT are THE number one improvement. The extrude hone is tied with agressive pcm tuning as the number two most important improvement.
The demand for SVT heads is low because you can port stock heads or send your own in for extrude hone after you port them. Those that want high performance tend to go even bigger with 3L engines, however, those are still expensive options.
See My Mods
Posts: 2,097 |
well in any case...I might be negotiable.
98 E0 SVT with some stuff
Posts: 4,292 |
...i'm still waiting...
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 638 |
I'm taking offers on parts off a '98 SVT motor I have on a stand, it's in the classifieds...
87 Mustang GT 5.0L TURBO
Posts: 118 |
I bought a 3L and svt heads for 400 bucks, p/up myself from a CEg'r in Columbus, OH only 2 hrs away. They came w/ valves as well....
SeSportV
1999 Silver Contour
SE Sport MTX (2.5)
Air Intake
Resonator Removed
Silver Rear Valence
Blue Turn Signals, Nozzles, Interior LED's
Custom Blue Trim
Single Silver Wiper (Bad A** and Unique)
15.9 1/4 mile @ 89 MPH
Posts: 1,572 |
My heads / valve covers are for sale too ! check classifieds
Check me out for awsome powder coating deals
www.powdercoatingworld.com
People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
