#93626 08/03/02 07:47 PM
Mandeep Offline OP
can help me out on how to wire my amp fuse...all the other amp wires have already been wired to the trunk...
Thanks
#93627 08/03/02 09:39 PM
Bwah? I don't understand the question. Here's my guess for your problem;
The main power wire that goes to the positve side of the battery should have an inline fuse ~6-12" away from the battery.
Hope this helps
99 navy blue SE Zetec ATX
Poke me for The Beast\'s profile
#93628 08/03/02 09:40 PM
Can you be more specific? Are you using a distribution block? You should have one inline fuse under the hood and then in the trunk you should have a distribution block which will house your fuses and allow you to split your power off to multiple amps.
#93629 08/04/02 12:16 AM
Mandeep Offline OP
sorry, i didnt realize how vague it was....
my 4 AWG amp wire was cut right at the battery, not attached to it, its just sorta hanging over the battery...how would i connect it to the battery?
Also where should i mount my fuse amp holder??
Moderated by  dnewma04_dup1
