Greeting`s
I have a 1995 Contour with a Four Cylinder Five speed Standard Trans and I have an overheating problem, or I should say the guage say`s it`s overheating plus I have no heat in the car, in the past when this type of thing happened I just replaced the thermostat and was happy.
But with all this talk of failed water pumps(impeller failure) should I replace that(the water pump) and the thermostat?
BTW This car has 175 thou km`s on it`s speedo.
Thank`s` for any help
cameraman46
if you never have, or don't know the cars history, the answer is emphatically YES!
on a lake in middle tn '98 mystique ls duratec atx de-badged, pin striped pre '98 sail panels b pillar black out mod silverstars- turns and highs in lows fogs on with parking lights mod
overheating guage + no heat from vents = no circulation through heater core.. ie, bad waterpump.
DONT run it anymore.. until you change that sucker out.
Ray
