Posts: 37 |
i just purchased a 1995 contour se v6 with 51000 miles on it.bought a warranty covering major engine,trans for 3 yrs.water pump will be 50% covered.im seeing alot of horror stories about the pump failures.when do they start exploding?60000,70000 etc.really cant afford to get it done now.is this something i can put off awhile and hope it happens during warranty,or should i change it asap?thanks
95 contour se 52000k electric red
Posts: 453 |
Originally posted by mrstooge: i just purchased a 1995 contour se v6 with 51000 miles on it.bought a warranty covering major engine,trans for 3 yrs.water pump will be 50% covered.im seeing alot of horror stories about the pump failures.when do they start exploding?60000,70000 etc.really cant afford to get it done now.is this something i can put off awhile and hope it happens during warranty,or should i change it asap?thanks
I looked in my haynes manual and saw no recommended schedule to replace it, although it's possible it was there and I didn't see it.
In some cases, such as a 4 cyl, it's not a bad idea to change it when you change your timing belt, but in your case I'm not sure how long they usually last. If you don't have the $$ right now, then I would just not worry about it. Be aware of the temp gauge so if it ever fails you hopefully will notice before your car overheats enough to do any damage. And I would also suggest that if you want to save money you could probably do it yourself without too much trouble. -Peter
Posts: 1,176 |
If you want it to last longer, replace your thermostat and while the thermostat is out do a COMPLETE system flush. The rubber hoses corrode and cause the pump to leak...
Bob
Posts: 7,100 |
Waterpump replacement takes 20 minutes, at most 40...
60 bucks for the part (or around that) and 30 minutes of your time... I can always afford that versus the 1200 for a new engine..
60,000 is pushing borrowed time(on the V6), as it usually runs..
Ray
'99 CSVT - Silver #222/276
Posts: 4,693 |
And 95 seemed to be the worst year for impeller failure on that water pump. If it still has the original, I would change it now before it fails so you won't be stranded when it happens.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 7,100 |
Its bad enough that EVEN THOUGH I have the revised impellar, I STILL travel, at all times, with a spare pump housing and gasket, coolant, and tools to change it no matter where I am..
Ray
Posts: 937 |
Hmm.. on my car it takes a few hours replace the water pump even with the right tools.
Posts: 7,100 |
I take it you have a 4cyl, then... Duratec is CAM driven, only thing on its own belt... tensioner moves by hand..
tada.. done.
Ray
Posts: 937 |
Originally posted by Ray: I take it you have a 4cyl, then... Duratec is CAM driven, only thing on its own belt... tensioner moves by hand..
tada.. done.
Ray
Yup, the 4 banger is what I have. You need to remove too many things that normally should not be a problem on any other car. Can't take all of that off in the front yard on a jack stand.
Posts: 7,100 |
Did it in the driveway of the house with the wife's 4cyl neon..
timing cover.. timing chain.. passenger side hub, pass. motor mount, damper puller..
replace.. re-time..
re-install everything.. A PITA!!!
Ray
